Power Switch Cables
Go to solution Solved by TrigrH,
11 minutes ago, Noobatologist said:
Is there any other way? Its just not going in all the way thats all, its very loose
its pins are smaller.
I have reused a motherboard from a Dell Optiplex 9010 and realized I have trampled over many stumps.
The main problem Im having right now though is the power switches, it's just weird and I'm not sure how to attach the cables. I've researched on the manual pdf but it only shows the whole cable instead of all the smaller cables.
Basically it's a 5 pin layout thingy and I'm just lost
https://linustechtips.com/topic/1075060-power-switch-cables/
It's usually at the bottom right of the board and not the top right.
Oops sorry, lemme take a look....
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/1075060-power-switch-cables/#findComment-12663971
2 minutes ago, TrigrH said:
The other three are apparently for a tri-color led. I've read that it might give you errors of those are not connected but that shouldn't be an issue.
https://www.dell.com/community/Optiplex-Desktops/Optiplex-5-pin-power-button-assembly-pinout/td-p/6234979
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/1075060-power-switch-cables/#findComment-12663978
2 minutes ago, Noobatologist said:
Do you have any idea about the other cables?
The reset, the hdd led, the power led + and - ?
You don't really need them. I never connect mine because the led's are annoying af, especially the hdd one.
If you have close up shots of the board we might find them tho.
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/1075060-power-switch-cables/#findComment-12663980
So with what I have, it wouldn't affect me at all right?
https://linustechtips.com/topic/1075060-power-switch-cables/#findComment-12663982
3 minutes ago, Noobatologist said:
I just tried plugging in the pins like that, it does not fit in.
you will need to take the plastic off the connectors and clamp the wires
https://linustechtips.com/topic/1075060-power-switch-cables/#findComment-12664047
https://linustechtips.com/topic/1075060-power-switch-cables/#findComment-12664064
17 minutes ago, Noobatologist said:
What happens when you continue with F1?
To me the board doesn't give away much, sorry :/
Maybe there are cheap adapters from Dell shit to real cases on eBay?
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/1075060-power-switch-cables/#findComment-12664215
37 minutes ago, Noobatologist said:
I got it working, I just booted it from the usb and installing windows rn. THANK YOU SO MUCH FOR ALL THE HELP
Good to hear! Cheers mate :)
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/1075060-power-switch-cables/#findComment-12664247
