Help with Cisco Catalyst 4948 10GE
Insprill
Hello! I just bought an old 4948 10gig off ebay and i need some help. I was following the steps to reset the password and i made a mistake And had to restart, and now i just keep getting this:
******** The system will autoboot now **********
config-register  = 0x2142
Autobooting using BOOT variable specified file....
Could not find a valid file in BOOT environment variable. BOOT variable can be set from IOS. To find currently set Rom Monitor variables, please type 'set' command.
For help choosing a boot method, type 'confreg' command.
rommon 1 >
Put in 'confreg 0x2102' (without the 's) and then type boot.
It looks like no boot statement is set so it's just dropping into rommon. This will make it boot from the first file it sees and keep the configuration moving forward.
Current Network Layout:
Current Build Log/PC:
Prior Build Log/PC:
Thanks soo much! But the only thing is, now every time i boot the switch, i have to type 'confreg 0x2102'
'boot'
is there a way so that i dont have to do that every time?
'boot'
Once you boot the switch, go into config mode and put in 'config-register 0x2102' and save the config.
Prior Build Log/PC:
Now whenever i type in 'configure terminal' i just get this
You need to be in EXEC mode to use configure terminal. Type en and it will get you where you need to be.
(It will then turn into Switch#)
Main Rig CPU: AMD Ryzen 7 5700x GPU: Asus TUF Gaming RX5700XT MBASUS AM4 TUF Gaming X570-Plus RAM: 64GB Corsair Dominator Platinum 3200 CPU Cooler: Cooler Master Master Liquid LC240E SSD: Crucial 250gb M.2 + Crucial 500gb SSD HDD: PSU: Thermaltake Toughpower Gran RGB 850W 80+ Gold Case: Corsair Carbide 275R KB: Glorious GMMK 85% MOUSE: Razer Naga Trinity HEADSET: Go XLR with Shure SM7B mic and beyerdynamic DT 990
unRAID Plex Server CPU: Intel i7 6700 GPU: Nvidia Quadro P2000 MB: Asus B150M-C RAM: Crucial Ballistix 32gb DDR4 3000MT/s CPU Cooler: Stock Intel SSD: Western Digital 500GB Red HDD: 4TB Seagate Baracude 3x 4TB Seagate Ironwolf PSU: EVGA BT 80+ Bronze 450W Case: Cooler Master HAF XB EVO KB: Cheap Logitech KB + Mouse combo
Ok so i did that, but still have to type it in every time.
i did
'en'
'exit'
'write mem'
then boot cycled it
i did
'en'
'exit'
'write mem'
then boot cycled it
Ah! I know what I forgot to mention.
You need to set a boot variable.
Once you boot back in do "dir" and then "conf t" and then "boot system flash:(image name)" and save that and reload.
Prior Build Log/PC:
