16 minutes ago, ASSASSINS13777 said:
ye asus h110m-r/c/si
8gb ram and uk and anout £200/£250
Oof, can’t really upgrade the cpu without upgrading the mobo too then... yeesh...
well, you could do this and just reuse your case, psu and ram. It’s not super insane, but should be a bit better than what you have while also having a decent upgrade path too, so if you’ve got money down the line and want to upgrade again, you could.
PCPartPicker Part List
Type Item Price
CPU AMD - Ryzen 3 1200 3.1 GHz Quad-Core Processor $64.89 @ OutletPC
Motherboard ASRock - B450M PRO4 Micro ATX AM4 Motherboard $75.61 @ OutletPC
Video Card ASRock - Radeon RX 580 8 GB Phantom Gaming X Video Card $169.99 @ Newegg
  Prices include shipping, taxes, rebates, and discounts
  Total (before mail-in rebates) $330.49
  Mail-in rebates -$20.00
  Total $310.49
  Generated by PCPartPicker 2019-06-19 22:54 EDT-0400
I got a ps5 and a pc pretty ballin
https://linustechtips.com/topic/1074452-pc-help/#findComment-12658883
will you ever be able to obtain more money in the future? because currently getting more money and then using it to get a better solution since you should be able to re use your ram, power supply case. The problem is that you have 2 components that are kinda balanced and they are very cheap. Cheap enough that upgrading one part or the other wont make to much of a difference. If you upgrade your GPU it might  be better at higher resolutions but then you will still have bad fps in actual fights or game play. If you upgrade your CPU you will get better more stable fps but only enough to the bottleneck your gpu and you will remain at lower resolutions. @star_pilot475 response is probably the best option. If you can get more money later on it would probably benefit you to upgrade your gpu first and rx 580 is a good pick. I also recommend this
Type Item Price
CPU AMD - Ryzen 5 1600 3.2 GHz 6-Core Processor $109.89 @ OutletPC
Motherboard Gigabyte - B450M DS3H Micro ATX AM4 Motherboard $71.88 @ OutletPC
Video Card PowerColor - Radeon RX 570 4 GB RED DRAGON Video Card $119.99 @ Newegg
  Total (before mail-in rebates) $316.76
  Mail-in rebates -$15.00
  Total $301.76
  Generated by PCPartPicker 2019-06-19 23:16 EDT-0400
https://linustechtips.com/topic/1074452-pc-help/#findComment-12658907
a bit over but:
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor  (£127.50 @ Aria PC)
Motherboard: ASRock - X370M Pro4 Micro ATX AM4 Motherboard  (£63.31 @ Egenisys)
Total: £190.81
Generated by PCPartPicker 2019-06-20 04:38 BST+0100
assuming your PSU is good enough, get this:
https://www.ebay.co.uk/itm/ASUS-Radeon-RX-480-Overclocked-4GB-GDDR5-Video-Graphics-Card-DUAL-RX480-O4G-GPU/254258456286?epid=2255869828&hash=item3b32fc26de:g:18YAAOSwCLxc~Mrz&frcectupt=true
https://linustechtips.com/topic/1074452-pc-help/#findComment-12658960
