I got a blue screen yesterday after upgrading my parts. it worked for awhile but then it blue screened. it still works I just dont want to start games until I know what happened. my psu worked before I was told it would work for my specs.( my specs are in my signature) if it happens again I will post a picture. if there is anymore info I need to give I will be happy to.
Current system CPU: Intel 4670k    MotherBoard: Asus z87-C   RAM: 12GB 1333mhz GPU: Sapphire AMD r9 290    Case: Corsair 200R    Storage: 250gb Sandisk SSD, 1tb segate barracuda HDD PSU: Corsair RM 850 Cooling: Corsair h100i No over clock
https://linustechtips.com/topic/107432-blue-screen-for-power-failure/
Have you tried a different PSU?
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
I dont have another one
Have you looked up the actual BSOD code number? That will tell you where the problem is most times.     Use BlueScreenView to find the code.
Desktop <dead?>
P8P67-WS/Z77 Extreme4/H61DE-S3. 4x4 Samsung 1600MHz/1x8GB Gskill 1866MHzC9. 750W OCZ ZT/750w Corsair CX. GTX480/Sapphire HD7950 1.05GHz (OC). Adata SP600 256GB x2/SSG 830 128GB/1TB Hatachi Deskstar/3TB Seagate. Windows XP/7Pro, Windows 10 on Test drive. FreeBSD and Fedora on liveboot USB3 drives.
Laptop <Works Beyond Spec>
HP-DM3. Pentium U5400. 2x4GB DDR3 1600MHz (Samsung iirc). Intel HD. 512GB SSD. 8TB USB drive (Western Digital). Coil Wine!!!!!! (Is that a spec?).
Did you overclock your video card?
PC Specs
Intel i5 4670k 4.2ghz @1.20v | Cooler Master 212 Plus | Asus z87-A | Fractal Design Define R4 |Hitachi 1TB 7200rpm HDD | 2x Samsung 840 EVO | Seasonic 520w m12II | Crucial Ballistix Sport 8gb DDR3 1600mhz | PowerColor 7870 GHz edition | Razer Blackwidow Ultimate 2013 | NZXT Hue RGB Controller
no I didnt
no I didnt
Whats parts exactly did you upgrade?
PC Specs
cpu motherboard and graphics card
