Hi all this might sound noobie but I am relatively new to PC building. But about this time last year I converted my PC build from a Mid tower ATX build to a Mini ITX build.
But recently I my computer has been acting up while gaming, so I opened up a program that lets me see the temperatures of my PC when I noticed something. The PCH was at 113oc, which i know is not normal. Is there anyway that I can solve this.
Thanks
https://linustechtips.com/topic/1073890-pch-overheating/
Thanks
What are the rest of your temps under load?
what case do you have? Is there enough airflow or does it get restricted ?
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
https://linustechtips.com/topic/1073890-pch-overheating/#findComment-12653927
11 minutes ago, Jack_arcomes said:
it hits 113oc under load, my case is a NZXT H200
What are the rest of your temps?
Also what motherboard /cpu do you use?
https://linustechtips.com/topic/1073890-pch-overheating/#findComment-12654311
