Hey guys, I have made an oopsie when it came to building a computer. So I have just built a PC however I didn’t realize that I need a GPU for graphics (rookie mistake).
My current build is:
CPU:AMD 1500X
MoBo: ASRock AM4 B450M Pro4 MicroATX
RAM: 8GB DDR4 3000mhz
PSU: CX450
Case: CoolerMaster Q300L
I’m looking to find the cheapest GPU/best GPU that can work with this MoBo.
https://linustechtips.com/topic/1071792-best-gpu-for-current-build/
That sucks! You should've gotten an APU but since you already have a cpu that isn't really an option. You could maybe get like a gt1030 if you really don't care about performance, but if you want to get a little better performance you could maybe get a used 1050?
Literally the cheapest PCIe card you can find should be find for outputting video
Ex-EX build: Liquidfy C+... R.I.P.
Ex-build:
Meshify C – sold
Ryzen 5 1600x @4.0 GHz/1.4V – sold
Gigabyte X370 Aorus Gaming K7 – sold
Corsair Vengeance LPX 2x8 GB @3200 Mhz – sold
Alpenfoehn Brocken 3 Black Edition – it's somewhere
Sapphire Vega 56 Pulse – ded
Intel SSD 660p 1TB – sold
be Quiet! Straight Power 11 750w – sold
If it's for gaming, the GPU is incredibly important, so buy something like a RX 570 in that case.
If you only want video output and do not need the GPU, a GT 210/710 is available for less than 30$ typically
Ryzen 7 3700X / 16GB RAM / Optane SSD / GTX 1650 / Solus Linux
Yeah, I didn't realize that I needed the GPU till after I was trying to run it, I thought I messed up with the whole build and thought I damaged the CPU, but it was just the GPU I needed. Thanks for the recommendation. I am just looking to get some casual gaming in, but nothing to run Triple A games or  do much besides getting a video feed
Not for any serious gaming, if anything, running a game and 720p 60fps at best, going to be using this just as a recording PC for I have a gaming one already up and running
16 minutes ago, Stitch_MJ said:
Wouldn't the MoBo need to be compatible with the GPU or just ANY PCIe GPU card?
Your motherboard is current, so any graphics card will work in the PCIe 3.0 slot.  Graphics cards really haven't been able to fully utilize the 3.0 slots, since they're quite fast and not really necessary for them, but they're good for extendin memory, like w/additional M.2 slots and such for increased speeds; it'll be even better for extra memory w/the PCIe 4.0 release comin out.
Any current and older card will work, since they're also backwards compatible (PCIe 2.0, etc).
Primary
OS:        Windows 10 - Professional (64-bit)
CPU:      i9-10900k 3.7-5.3GHz (10th gen)
GPU:      EVGA RTX 3080ti FTW3 Ultra Gaming 12gb
MB:         ASUS RoG Maximus XIII Hero (ATX)
RAM:      64gb (4x16) DDR4-3200MHz G.Skill TridentZ Silver/Black (CL16)
HD:         1x 8TB Corsair MP400 NVMe PCIe 3.0 (SSD)
               2x 16TB Seagate Exos 7200rpm (HDD)
E-HD:     12TB WD
PSU:       EVGA 1000w G2, 80+ Gold (modular)
UPS:       900w CyberPower
Display:   ASUS 27” 1440p/270Hz IPS 0.5ms (XG27AQM)
                Aorus 27" 1440p/165Hz IPS 1ms (FI27Q-P) iGPU
KeyB:      EVGA Z15 (wired)
Mouse:    Logitech G-502 Hero (400/600/800/1000)
Headset: JBL Quantum ONE Gaming Headset
Case:      Cooler Master MasterCase H500P Mesh (ATX)
Other:     XB-1 Wireless Controller Adapter w/Controller
              NPET H01 Gaming Mouse Bungee Cord Holder w/4 USB Ports
Gaming Computer Specs.pdf
If it's a separate i.e. streaming PC, then a GT 210 will probably work just fine; just be sure to use the CPU for rendering/etc
Thank you, I will take a look into this!
