Hi everyone, I am really new here, and I would like to you guys tell me what you think about my rig. I already built the rig and sorry for my english(not my primary language)
So here it goes the specs:
MotherBoard: Asus Rampage IV Extreme
CPU: Intel i7 3930K Hexa-core(not overclocked)
GPU: EVGA 660ti Superclocked + 3GB
RAM: 32GB Vengeance 1600MHz quad-channel
Watercooler: Corsair H100
SSD: Samsung 830 128GB
HD: 2TB Seagate
Power Supply: Corsair HX1050
Case: Cosmos 2
Keyboard: Razer Arctose
Mice: Razer Deathadder Black Edition
Well that is my build, I still want to change a few thing one of them is the GPU and Watercooling, I want a better GPU and put a nice custom loop inside. The powersupply I know is overkill, but I was worry about not having enought power for later upgrades, right now is all stock, but runs everything good and without any problem, I like amazing graphics, but I know my GPU cant handle Crysis 3 on ultra, but still even on High an amazing Graphic with a nice FPS.
Let me know what u guys think.
Edited by Nerykrugeer
Everyday Rig: CPU: Intel i7 3930k (stock), Graphics Card: Asus Strix GTX 1080 Advance Edition, Ram: 32Gb 1600MHz Corsair Vengeance, Storage: 128Gb Samsung 830, 2Tb Seagate Barracuda, CPU Cooler: H100i GTX Noctua F12 iPPC 2000RPM and Gentle Typhoon 1850RPM, Windows 10 Pro, Power Supply: Corsair HX1050 80Gold, Case: Phanteks Enthoo Luxe Keyboard: Corsair K65 Cherry Red,  Mouse: Razer Mamba TE
https://linustechtips.com/topic/10717-my-first-rig/
less RAM maybe just one TB and upgrade later. and get a better graphics card and it will be perfectly even
i5 3570 | MSI GD-65 Gaming | OCZ Vertex 60gb ssd | WD Green 1TB HDD | NZXT Phantom | TP-Link Wifi card | H100 | 5850
“I snort instant coffee because it’s easier on my nose than cocaine"
https://linustechtips.com/topic/10717-my-first-rig/#findComment-114581
Great rig, packing a lot of horsepower. Maybe even a bit over-powered in terms of CPU and RAM for a gaming rig, are you using it for anything else as well? With that CPU+motherboard+cooler combination, are you planning on overclocking soon?
Edit: Just to clarify, is this a build you're planning or one you've already built?
https://linustechtips.com/topic/10717-my-first-rig/#findComment-114587
CPU seems overkill for a 660Ti, as well as RAM, I'd go for a 3770k and 16GB, unless you upgrade to a GTX 680 or above/ AMD 7970 or above
PC: EVGA GTX680, i5 2500K, 8GB Kingston HyperX, Gigabyte Z68-GA-UD3P, 120GB OCZ SSD, 2x1TB WD Greens, Corsair 600t, Corsair AX750, Corsair H100i, ASUS MX239H, Corsair K60 + M60.
https://linustechtips.com/topic/10717-my-first-rig/#findComment-114590
Conelton:
I already build this one, I use for some video editing but which is rarely, but more for gaming, and is for long term, and I am not planing to overclock because of life spam gets reduce.
Tommy:
I am planning to upgrade to GTX 680 when I start to do the custom loop, I want to put the EVGA gtx 680 hydro series, and the RAM the price difference when I bought wasnt so much, so I put some more money in the ram I was thinking on 16, but because of the sale I got the 32
https://linustechtips.com/topic/10717-my-first-rig/#findComment-114616
I love it! Only thing I would change is the GPU though.
Maybe a GTX 680 or a 7970GHz Edition. Both are very very good cards.
CPU: Intel i7 4790k Motherboard: ASUS Maximus VII Formula RAM: Corsair Vengeance Pro 32GB 2400MHz: GPU: 2x EVGA GTX 780 Ti's with ACX cooling PSU: Corsair AX1200 Watt Gold SSD: SanDisk Extreme 120GB SSD (Operating System) SSD: Mushkin Chronos 240GB (Games) Sound card: Creative Sound Blaster ZxR HDD: Seagate 3TB External OS: Microsoft Windows 8.1 Mouse: Logitech G502 Gaming mouse Keyboard: Corsair Vengeance K60 MX Red switches Monitor: ASUS VG248QE 144Hz
https://linustechtips.com/topic/10717-my-first-rig/#findComment-114630
If you are going to upgrade the GPU and you want to keep this system for the long term, get a Titan instead of a 680. There are waterblocks available for it as well :) Your CPU is way overpowered for even a 680.
Desktop: Intel Core i7-5820K, Corsair H115i, Asus X99-Deluxe/USB 3.1, G.Skill Ripjaws4 32GB 2800MHz CL16, Zotac RTX 3070, Samsung 950 Pro 512GB in Angelbird Wings PX1, Samsung 850 EVO 1TB, 5*Seagate 12TB, Cooler Master V1200, Phanteks Enthoo Luxe, Windows 10 Pro. Phillips 328P6VUBREB, Corsair Vengeance K95 RGB Cherry MX Brown, Logitech G502 X Plus, Sennheiser HD700.
AYANEO 2S: AMD 7800U, 32GB 7500MHz, 2TB WD SN850X. Windows 11.
https://linustechtips.com/topic/10717-my-first-rig/#findComment-114652
ya i have xfire 7970s and they kick ass in EVERYTHING with a i7 x79 platform and all i am using is an 850w psu and 16gb ram that is all u need tbh i would go with an AX psu not an HX so that it is fully modular and also maybe if u wana splurge look into the tj11 it is a kickass case for watercooling so ya those are just my tips Good Luck xD
https://linustechtips.com/topic/10717-my-first-rig/#findComment-115022
Nice can we get some pics or are there already some and my phom e don't show em
I will put some pics later, when I get some cable management done
https://linustechtips.com/topic/10717-my-first-rig/#findComment-115220
Tommy:
Fair enough, although if you will be upgrading soon, it might now be worth dropping money on a 660Ti. It may be more worth your money to get a previous gen card, or second hand - unless you have a secondary system to put the 660Ti in once it's time is done. If you want to spend money on RAM, go for it! the more the better :)
https://linustechtips.com/topic/10717-my-first-rig/#findComment-115936
Is this rig for gaming? If so, that CPU is wayyyy overkill (Even for basic editing) but since you've already built it, just leave it.
I would change the RAM to 16GB (Unless you do editing/3D work)
You're fine with a 850W PSU
And I guess you can change the GPU to a 670/680/7970
https://linustechtips.com/topic/10717-my-first-rig/#findComment-115989
