how much power?
Go to solution Solved by LukeSavenije,
Just now, Jam_jam2 said:
so the formula is the best of these 3?
I'd say yes
9 minutes ago, Jam_jam2 said:
so what brand would you recommend then?
i don't recommend brands, because that's flawed as hell. have a psu tier list (I'd recommend a or higher, but b will do)
3 minutes ago, SpiralTTGL said:
500w is fine for this setup, however these parts are pretty pricy are you willing to risk it with that powersupply?
it's not even good... fractal doesn't make PSUs themselves, it's a really cheap fsp
https://linustechtips.com/topic/1071603-how-much-power/#findComment-12634978
so for im thinking of the Corsair CX650M , Be Quiet! Pure Power 11 600W, BitFenix Formula Gold 650W
cxm is a cwt dual forward, will probably whine
pp11 is a custom made fsp, pretty nice unit
formula is a custom cwt gps, nicest of these 3
https://linustechtips.com/topic/1071603-how-much-power/#findComment-12635026
