9 minutes ago, Jirayr said:
Ok but can I use 2080ti with ryzen 3000 or there is gonna be some bottleneck?
Wouldn’t you want a Quadro card tho? If you main aim (>80%) is 3d rendering.
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
https://linustechtips.com/topic/1071139-building-pc/#findComment-12630964
Which rendering program/engine do you use?
A Quado is likely not a wise use of your money. Many rendering engines only utilize the CPU, and those that are GPU-based run just fine on the consumer cards (speaking from experience here).
2080ti should be great - Autodesk has committed to support real-time ray tracing via Nvidia RTX cards, so if you use their programs, you might have some at the least.
Screwdriver specs: Long, pointy. Turns things. Some kind of metal.
Main rig:
i9-7900x | Asus X299-Prime | 4x8GB G-Skill TridentZ @3300MHz | Samsung 970 Evo 500GB | Intel 5400S 1TB | Corsair HX1200
unRAID server:
Xeon  E5-1630v4 |  Asus X99-E WS | 4x8GB G-Skill DDR4 @2400MHz | Samsung 960 EVO 250GB cache drive | 12TB spinning rust | Corsair RM750X
FreeNAS server:
AMD something-or-other | Asus prebuilt sadness | 8GB DDR3-1600 | 9TB magnetic storage | Potential fire threat
HTPC:
i7-4790 | GTX1650 | Dell Sadness | 12GB DDR3-1600 | Samsung 860 250GB | 1TB magnetic storage | James Loudspeaker SPL3 x2 | Corsair SF450
https://linustechtips.com/topic/1071139-building-pc/#findComment-12630970
Mostly Maya but actually I need both CPU and GPU to be perfect. But If it's not a big difference between Ryzen 2000 and 3000 I'll go for cheaper one. And do I need to take in consider taking AMD videocard instead of 2080ti ?
https://linustechtips.com/topic/1071139-building-pc/#findComment-12631498
4 minutes ago, Jirayr said:
I would like to but they are too expensive
Get a 3rd-Gen Ryzen 7 and a 2080 Ti. That'll be a good combo. Tight in a $2500 budget but probably doable if you're willing to sacrifice aesthetics and storage space.
CPU: Core i9 12900K || CPU COOLER : Corsair H100i Pro XT || MOBO : ASUS Prime Z690 PLUS D4 || GPU: PowerColor RX 6800XT Red Dragon || RAM: 4x8GB Corsair Vengeance (3200) || SSDs: Samsung 970 Evo 250GB (Boot), Crucial P2 1TB, Crucial MX500 1TB (x2), Samsung 850 EVO 1TB || PSU: Corsair RM850 || CASE: Fractal Design Meshify C Mini || MONITOR: Acer Predator X34A (1440p 100hz), HP 27yh (1080p 60hz) || KEYBOARD: GameSir GK300 || MOUSE: Logitech G502 Hero || AUDIO: Bose QC35 II || CASE FANS : 2x Corsair ML140, 1x BeQuiet SilentWings 3 120 ||
LAPTOP: Dell XPS 15 7590
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
https://linustechtips.com/topic/1071139-building-pc/#findComment-12631510
A 2700x + 2080Ti would even do here. We don’t know benchmarks yet
but considering what he wants to do, might be advisable to find a quadro card second hand
https://linustechtips.com/topic/1071139-building-pc/#findComment-12631624
Absolutely, you need both a CPU and GPU. I prefer Nvidia cards, simply because Autodesk programs are optimized for Nvidia hardware. AMD cards will run just fine, but with the AMD "dry spell", Autodesk made most of their improvements to the graphics side of things with Nvidia cards in mind, so they typically pull ahead just a bit. But in the end, whatever brand makes you happy will perform adequately so long as you get a powerful card.
Unless you are using a third-party rendering engine, (such as VRay) you will likely be using Arnold, which is 100% CPU-bound while rendering, so you won't need more than one card.
What I'm getting at is, 2700X + 2080ti should be fine.
And I'd like to reiterate, a "professional" GPU will add literally nothing to your workflow. I've used machines with Quadro and Geforce cards extensively for 3d CAD and rendering, and there is not a bit of difference between them. I'm not saying that Quadro or FirePro cards don't have a place, but for you they won't add any value, and are VERY expensive for the budget-minded.
Main rig:
unRAID server:
FreeNAS server:
HTPC:
https://linustechtips.com/topic/1071139-building-pc/#findComment-12631654
Thank you for your feedbacks they are helping me a lot.
https://linustechtips.com/topic/1071139-building-pc/#findComment-12632641
