4 minutes ago, just that pc guy said:
its like zzzzz......zzzzzzz.zz.zz.z.z like that its not pattern nor constant
That's coil whine. You'll especially hear it while playing games at a high frame rate. Usually not much you can do about it. Changing the PSU may help, or trying a different PCIe port if available. My solution is to increase the volume in a game.
https://linustechtips.com/topic/1070467-imma-need-some-help/#findComment-12625629
o god thats good, i could care less about a bit of noise lol, i was just wondering if it would like fry my mobo, its an old optiplex 780 lol.
https://linustechtips.com/topic/1070467-imma-need-some-help/#findComment-12625632
Nah it's normal. and actually there is something you can do about it. The source of the sound is interference from motherboard and GPU to your sound chip and/or route. If you used a sound card, or usb audio output. Then there wouldn't be any noise.
https://linustechtips.com/topic/1070467-imma-need-some-help/#findComment-12625639
