Fellas, I was planning on building a PC, but might just go with a prebuilt because of the plug and play to it, or is it a much better Idea to build it myself? Also, I'd like if y'all could check out this parts list and let me know how that looks? And maybe some things that could be better? https://pcpartpicker.com/list/KQXF7W
https://linustechtips.com/topic/1069943-help/
PCPartPicker Part List
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor  ($145.78 @ OutletPC) wait for zen 2 if possible.
Motherboard: ASRock - B450 Pro4 ATX AM4 Motherboard  ($69.89 @ OutletPC)
Memory: Team - Vulcan 16 GB (2 x 8 GB) DDR4-3000 Memory  ($66.89 @ OutletPC)
Storage: Inland - Professional 512 GB M.2-2280 Solid State Drive  ($54.99 @ Amazon)
Storage: Seagate - Constellation ES 3 TB 3.5" 7200RPM Internal Hard Drive  ($51.99 @ Amazon)
Video Card: MSI - GeForce RTX 2080 8 GB VENTUS OC Video Card  ($689.99 @ Newegg)
Case: Cooler Master - MasterBox TD500 ATX Mid Tower Case  ($54.99 @ Newegg)
Power Supply: Corsair - RMx (2018) 550 W 80+ Gold Certified Fully Modular ATX Power Supply  ($62.98 @ Newegg)
Total: $1197.50
Generated by PCPartPicker 2019-06-04 21:42 EDT-0400
https://linustechtips.com/topic/1069943-help/#findComment-12621248
CPU: Intel - Core i5-9600KF 3.7 GHz 6-Core Processor  ($239.99 @ Newegg)
CPU Cooler: Cooler Master - Hyper 212 Black Edition 42 CFM CPU Cooler  ($31.99 @ Amazon)
Motherboard: Gigabyte - Z390 UD ATX LGA1151 Motherboard  ($109.99 @ Newegg)
Storage: HP - EX920 512 GB M.2-2280 Solid State Drive  ($65.89 @ OutletPC)
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive  ($59.89 @ OutletPC)
Video Card: EVGA - GeForce RTX 2070 8 GB Black Video Card  ($479.99 @ Amazon)
Case: Cougar - MX340 ATX Mid Tower Case  ($49.99 @ B&H)
Total: $1167.60
Generated by PCPartPicker 2019-06-04 21:58 EDT-0400
https://linustechtips.com/topic/1069943-help/#findComment-12621270
When looking at pre-builds you will not get specs anywhere near the parts-builds you see here.  If you are willing to build it yourself the big reward is in the value and horsepower you get for your buck.
https://linustechtips.com/topic/1069943-help/#findComment-12621275
It depends on your budget and what you plan to do. For example, f you are on a tight budget you could get yourself a Dell Optiplex add a GPU upgrade your power supply to support it then boom you have your tight budget pc. If you are not on such a tight budget and you know what parts to use go to www.pcpartpicker.com and use the system builder tool to build your own based on what you would like or look at pre-built computers.
https://linustechtips.com/topic/1069943-help/#findComment-12621311
Total: $1197.50
Is the 2080 a good pair with the 2600? Wouldn't the 2080 be bottlenecked?
https://linustechtips.com/topic/1069943-help/#findComment-12621318
Read his post, he already did link PCPartPicker, the build he made has a budget of $1190.
https://linustechtips.com/topic/1069943-help/#findComment-12621399
the 2600 won't bottleneck the 2080.
https://linustechtips.com/topic/1069943-help/#findComment-12621408
It won't bottleneck it per se, but the Intel equivalent chip will outperform it by a little on average, and in some games by a wide margin. See here for details:
https://www.techspot.com/review/1829-intel-core-i5-9400f-vs-amd-ryzen-5-2600x/
That said, here's a build using the 9400F. Ideally, I'd like to get you onto a 9600K instead, because the numbers are even better when it's OCed to 5.0GHz, but the 9400F should suffice with an RTX 2080:
https://linustechtips.com/topic/1069943-help/#findComment-12621535
