Help: Overclocking different speed ram
Solved by nick name,
You're gonna be bound to the limits of the worst performing stick. That means voltage, timings, speed. So if your 2400MHz needs 1.4V to run at 2666MHz then you gotta run both at 1.4V and 2666MHz. Same for timings. If your worst stick needs CL 16 then both will be CL16.
voltigeurramon ·
Posted in Troubleshooting1 -
1
Vibora ·
Posted in New Builds and Planning4 -
5
3
Doctah ·
Posted in Peripherals3 -
8
michaelb198 ·
Posted in Peripherals2
