hi. i just installed HD Tune pro, and found this.
in the attachments u can see i got errors. im not a hard drive expert, (not even a beginner) can some one help me and tell what is this? should i worry about this? its on my other computer and this drive is the main drive where my OS is installed. what should i do? is it serious?
post-35389-0-44567900-1390703341_thumb.j
Current Rig: Intel core i7 4770K Stock 4.5G, Asus Maximus VI Hero, Corsair Vengeance 1600Mhz 16Gb (8Gx2), 2x SLi Gigabyte Geforce GTX 670 2Gb GDDR5 3X Windforce Edition, Corsair Hydro Series H100i (Push), JDS LABS O2/ODAC combo, Fiio E18 KUNLUN, Asus Xonar Essence STX (secondary PC), Sennheiser HD700, Hifiman HE 400i, Beyerdynamics DT 990 PRO 250 Ohm, Sennheiser HD 518, Cooler Master Silent Pro M2 850W 80+, Cooler Master CM 690 II Advanced, Samsun4g DVD R/W Combo, 3X Cooler Master 120mm Blue LED fans, LG IPS 23EA73, Logitech G710 BLUE, BlackWidow Ultimate 2013 Edition,Logitech G402 HYPERION FURY, Bloody Core V7, SteelSeries QcK Mass MiBR mouse pad
https://linustechtips.com/topic/106976-hard-drive-dead/
Too many reallocated sector means dive is more prone to failures.
Your drive have millions of sectors so a few hundreds is relatively small.
thanks for reply but can u guys pls be more simple and straight in ur answers? i mean is it bad? should i change it? any way to solve it?
https://linustechtips.com/topic/106976-hard-drive-dead/#findComment-1429807
Yes. Better to replace it as soon as you can. You are in danger of data loss.
It already self corrected by reallocating. You can recheck your drive with any of the free diagnostic tools in these toolkits.
http://www.gfi.com/blog/top-5-free-rescue-discs-for-your-sys-admin-toolkit/
ok thanks guys. i m about to get my ssd soon. just wanted to ask if there is any way to completely format the complete hard drive like we can format usb drive. is there any safe way or software to format full hard drive so that i can remove the windows installation as well?
and one more question, if a drive does not have windows on it, and is used just as storage drive, if it fails, and dies during computer is on, will it effect windows in anyway?
https://linustechtips.com/topic/106976-hard-drive-dead/#findComment-1430087
It's not a life or death situation yet, but bad sectors definitely aren't good. Replace it in the next month or so to be safe.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/106976-hard-drive-dead/#findComment-1430092
I'm not sure about the first one (I don't know of any software, and I can't really look for any right now), but as for the second one, no. Unless the Windows install is spanned to that drive (like in some RAID configs), nothing will happen, unless you have programs on it (then they obviously won't work).
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/106976-hard-drive-dead/#findComment-1430111
