so i have a pi zero w /w wide angle camera module
and now id like to use it as an actual webcam on my pc .
i figured motioneyeos would give me a ip camera style webstream
now i only need a piece of software that simulates a traditional webcam using a web adress source so i can tell these stupid programs to use it for lets say discord or skype or whatever
i read about a couple of tools now but none seem ideal
is anyone running an ip cam as webcam?
"You know it'll clock down as soon as it hits 40°C, right?" - "Yeah ... but it doesnt hit 40°C ... ever  😄"
GPU: MSI GTX1080 Ti Aero @ 2 GHz (watercooled) CPU: Ryzen 5600X (watercooled) RAM: 32GB 3600Mhz Corsair LPX MB: Gigabyte B550i PSU: Corsair SF750 Case: Hyte Revolt 3
https://linustechtips.com/topic/1069740-using-pi-zero-w-as-ipvirtual-webcam/
When I was using my Raspberry Pi as a webcam with the camera module I used software called motion and it was awful. It capped out at 10 FPS with 640x480 resolution, it took decent stills (not as good as a 5 or 6 year old smartphone), but video was barely watchable. I was just recording though so you might have better luck streaming but IMO you'd be better off getting an old Android smartphone and using one of the many free IP camera apps to stream it to your PC if quality is a concern.
-KuJoe
thanks. well quality is a concern but also i just really wanted that wide angle view. my v30 is supposed to have wide angle front cam but idk its not that extrem ill tinker around when i get home and ill check out motion right if you can send me a link
There was a LTT video on setting up Pi's as webcams that might help.
🖥️ Motherboard: MSI A320M PRO-VH PLUS  ** Processor: AMD Ryzen 2600 3.4 GHz ** Video Card: Nvidia GeForce 1070 TI 8GB Zotac 1070ti 🖥️
🖥️ Memory: 32GB DDR4 2400  ** Power Supply: 650 Watts Power Supply Thermaltake +80 Bronze Thermaltake PSU 🖥️
🍎 2012 iMac i7 27";  2007 MBP 2.2 GHZ; Power Mac G5 Dual 2GHZ; B&W G3; Quadra 650; Mac SE 🍎
🍎 iPad Air2; iPhone SE 2020; iPhone 5s; AppleTV 4k 🍎
