7 minutes ago, Empty__ said:
Built a new pc, motherboard gives me AE code and I can’t install an os I’m just stuck here
Do you have an windows installation disk?
Main PC:
CPU: AMD Ryzen 7 5700X3D | RAM:Corsair LPX 3200 mhz (32GB)
Mobo:ASUS Strix B550-F Wifi | GPU: Gigabyte 9070
Case: Sharkoon Nightshark RGB| Storage: 500 GB 970 EVO Plus 1 TB WD blue 500 GB Samsung HDD
Monitor: iiyama G-Master G2470HSU-B1 165Hz
Powersupply: Cooler Master GX III Gold 750
Main Laptop
CPU: AMD Ryzen 7 4800H | RAM: Team group 16 GB 2666 mhz
GPU: RTX 2060 (MXM swappable)
Monitor: 1080p 120Hz
Storage: 2x 1 TB Samsung 970 EVO NVMe (no raid)
Second Laptop
CPU: Intel Core I5 1235u,  RAM: Crucial 16 GB 3200 mhz
GPU: IrisXe 80 eu
Storage: 512 GB WD Digital SN530 NVMe
Phone:
Xiaomi MI 11
Work Phone:
Samsung Xcover 6pro
https://linustechtips.com/topic/1069611-help-please/#findComment-12618353
Just now, Empty__ said:
No I have a windows media creation tool usb stick
Use that to create an bootable USB stick (the tool does that for you) follow the steps and plug it into your pc
Main PC:
Main Laptop
Second Laptop
GPU: IrisXe 80 eu
Phone:
Xiaomi MI 11
Work Phone:
Samsung Xcover 6pro
https://linustechtips.com/topic/1069611-help-please/#findComment-12618375
Could you elaborate? This is my second pc and for my first one I simply stuck the usb stick in when it gave me this screen
https://linustechtips.com/topic/1069611-help-please/#findComment-12618380
I don't follow you quite. Did it gave that screen after you plugged the usb in your first pc?
Main PC:
Main Laptop
Second Laptop
GPU: IrisXe 80 eu
Phone:
Xiaomi MI 11
Work Phone:
Samsung Xcover 6pro
https://linustechtips.com/topic/1069611-help-please/#findComment-12618387
Sorry for the confusion. Just sold my first pc, I built my second pc and am now trying to install windows on it. When I built my first pc I simply plugged in the usb stick with the media creation tool on it into the USB port and it booted windows. This time however it is not doing that.
https://linustechtips.com/topic/1069611-help-please/#findComment-12618397
maybe the stick doesn't contain windows anymore. Could you check and make sure it looks like this
Main PC:
Main Laptop
Second Laptop
GPU: IrisXe 80 eu
Phone:
Xiaomi MI 11
Work Phone:
Samsung Xcover 6pro
https://linustechtips.com/topic/1069611-help-please/#findComment-12618406
The usb stick looks like this. And I think I might have been dumb and not have actually double clicked the tool to set up windows
Go ahead and set up windows then :)
Main PC:
Main Laptop
Second Laptop
GPU: IrisXe 80 eu
Phone:
Xiaomi MI 11
Work Phone:
Samsung Xcover 6pro
https://linustechtips.com/topic/1069611-help-please/#findComment-12618419
Thank you, if this works then you are a god send of a week long problem
no problem. I am happy to help. you may want to need to move tool to the internal drive of the pc. Because the usb must be formatted before it can be used. the tool also does this automatically
Main PC:
Main Laptop
Second Laptop
GPU: IrisXe 80 eu
Phone:
Xiaomi MI 11
Work Phone:
Samsung Xcover 6pro
https://linustechtips.com/topic/1069611-help-please/#findComment-12618428
Thank you it all worked an I’m an currently re-downloading half a terabyte of games and software, all I have left is to overclock
https://linustechtips.com/topic/1069611-help-please/#findComment-12620062
