I'm trying to overclock my AMD FX-8320 with my MSI 970A-G46 motherboard and im running into an issue with voltage. Whenever i change the cpu voltage or even while it's at stock, it seems to always jump around and not stay constant. This causes errors in prime95 if i try to go over 4GHz because the voltage will dip too low, whenever it feels like it, to supply the cpu with sufficient power. Any suggestions?
https://linustechtips.com/topic/106945-cpu-voltage-issue-when-overclocking/
That board isn't really meant for overclocking an 8 core as it has a 4+1 power phase vrm design. I would enable load line calibration to keep the voltage stable at high load.
[AMD Athlon 64 Mobile 4000+ Socket 754 | Gigabyte GA-K8NS Pro nForce3 | OCZ 2GB DDR PC3200 | Sapphire HD 3850 512MB AGP | 850 Evo | Seasonic 430W | Win XP/10]
basically  everything Ryan said is true, but I wanted to add the same suggestion so I'll just bold it.
CPU: R5 1600 @ 4.2 GHz; GPU: Asus STRIX & Gigabyte g1 GTX 1070 SLI; RAM: 16 GB Corsair vengeance 3200 MHz ; Mobo: Asrock Taichi x470; SSD: 512 gb Samsung 950 Pro Storage: 5x Seagate 2TB drives; 1x 2TB WD PurplePSU: 700 Watt Huntkey; Peripherals: Acer S277HK 4K Monitor; Logitech G502 gaming mouse; Corsair K95 Mechanical keyboard; 5.1 Logitech x530 sound system
 01000010 01101001 01101110 01100001 01110010 01111001 00100000 01100100 01101111 01100101 01110011 01101110 00100111 01110100 00100000 01101101 01100001 01101011 01100101 00100000 01111001 01101111 01110101 00100000 01110000 01110010 01101111 00101110
This article  will probably help you.  This should specifically address your problem.
Isopropyl alcohol is all you need for cleaning CPU's and motherboard components.  No, you don't need [insert cleaning solution here].  -Source: PhD Student, Chemistry
Why overclockers should understand Load-Line Calibration.
ASUS Rampage IV Black Edition || i7 3930k @ 4.5 GHz || 32 GB Corsair Vengeance CL8 || ASUS GTX 780 DCuII || ASUS Xonar Essence STX || XFX PRO 1000W
