No POST with D0 Code
Solved by SilentKoder,
I've tried to reseat the cpu pin twice as well as ram several times. I also tried qflash+ but it didn't seem to do anything. Is it supposed to automatically update the bios from the usb? I've started request for RMA, not sure how long it will take. In the meantime, is it a good idea to buy another MB and try it on?
Edit: Got it tested and it was the motherboard that is not working. Will have to RMA or buy a new one.
