xbox problem with cd reader.
I remember that little doohicky. Replacing it does squat, the motherboard is shorted somewhere along the lines. I replaced the motor, the disk drive... didn't do me any good for the exact same issue with the exact Lite-On drive (there are multiple versions, this one is not the lucky one).
You can create a bridge somewhere near where the CD drive sits, but requires soldering. It's the only fix I know of, and I can't even remember where to start. If you're willing to do some solder work, I could probably find it. I never did it so I can't prove it works, but you've got an otherwise broken Xbox on your hands, so it's worth trying, hm?
I've found a new drive that was cheap, so i think i will just try to replays the drive, But thanks for the help tho! ![]()
