Project X is my first custom built PC. It is relatively budget only costing £150. Isn't fully built yet. Pictures will be released Thursday next week.
Specs :
Motherboard : MSI A55M-E33
CPU cooler : RGB cooler from ebay
RAM : 8GB DDR3
HDD : 160GB WD blue
Case : Areocool Areo 500 RGB
PSU : 350w seasonic
If you want me to see your reply, please tag me @Faisal A
https://linustechtips.com/topic/1068731-project-x/
Specs :
RAM : 8GB DDR3
HDD : 160GB WD blue
PSU : 350w seasonic
cpu andmobo should be fine (checked with msi's compatibility list)
cooler correct me if I'm wrong but should be the same TechYesCity used in this build and he Didn't mention any problems(also 135W tdp but not FM2/FM2+ compatible for what I can read) (another video with this cooler) (link to the cooler)
HDD 160gb U sure?
https://linustechtips.com/topic/1068731-project-x/#findComment-12611068
https://linustechtips.com/topic/1068731-project-x/#findComment-12611072
