I currently use a HP notebook, whenever i open intel graphics control panel only the following loading screen appears after this loading screen nothings pop-ups. Even tried reinstalling windows but no change.
I downloaded the drivers though windows update both the times.
Processor- i5 8250U , UHD graphics 620.
https://linustechtips.com/topic/1068421-need-help-asap/
Try going to Intels website and download the latest drivers.
Also, what do you want to do in the control panel?
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/1068421-need-help-asap/#findComment-12608613
22 minutes ago, Dhruv Kansal said:
want to change the power setting and also wanted to change contrast and brightness of my display
You should be able to do that in the Windows 10 "Settings" as well, but do try and update the drivers for the Intel HD Graphics. You can try uninstalling them and reinstalling them as well. Have you restarted the laptop itself at all?
CPU i7 8700K ( 5 GHz) RAM G Skill Trident Z 32 GB (3200 MHz) GPU EVGA RTX 2080 XC Ultra Motherboard Asus ROG Strix z370 E Gaming Cooling NZXT Kraken x62 R2 PSU EVGA SuperNova 650 W 80+ Platinum Storage 500 GB Samsung 970 EVO NVME M.2, 1TB Samsung 860 EVO M.2, 1TB Samsung 850 EVO SATA, 1TB Samsung 860 EVO SATA Display Dell QHD 144Hz 27'' Case NZXT H500 Black Keyboard Corsair K95 RGB Platinum Mouse Logitech G900 Operating System Windows 10 Pro
https://linustechtips.com/topic/1068421-need-help-asap/#findComment-12608676
Hey please use either the quote function (as I just did) or tag people with @Dhruv Kansal.
So have you tried getting the driver from Intels site?
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/1068421-need-help-asap/#findComment-12608678
