Hello. So 2 days ago i bought a new CPU AMD FX8350 and a Kingston 480gb ssd. All wen't well after i put them in so i tried to play a game and my pc crashed after only a few minutes. This happened several times until i decided to install new windows on the SSD to check if that's the culprit. So i did that and the same thing happened but after a longer time than a few minutes. I'm thinking it could be the power supply because i made a stress test on the cpu, gpu and both passed it and when i tested the psu my pc crashed after a few seconds after i started the test. Any thoughts? Let me know if my pc specs are needed and i will add them here. Thank you in advance!
https://linustechtips.com/topic/1068165-problem-after-upgrading-cpu-and-adding-ssd/
Thank you for the answers. I wanted to make sure before i tried to refund them. Any idea how i can get around this so i can play some games before buying a new PSU? I tried to lower the max processor usage from Power Management to 60% but it still crashes after a while. Also, what kind of PSU should i look into buying?
