okay all I have a project I've been stewing on for a while now and I figured I'd start posting about it here.
I have a launch day ps3 that me and my dad put many hours together with and I want to keep it around as long as possible.
I've already got 90% of the materials and work done, all I have left is tubing and wait for a combo CPU and GPU block to come in the mail. this motherboard is a test board and is dead so don't freak out.
first off the case if a half xb EvoIMG_20190529_002607.thumb.jpg.50c53229d3b6ec08550e27287ee2dacb.jpg
I was originally going to use some random case I got off Facebook marketplace but it ended up being just too small for the motherboard
here is the lower level layout with disk drive, power supply, and pump
I'm using a 280 and 120 rad to cool everything
so far easy right, welp it only got harder from here
fan control and disc drive mounting and modification
  1. to be continued
https://linustechtips.com/topic/1067925-ps3-water-cooling/
That's looking pretty sweet, I think I may do the same thing with an original xbox.
Good stuff!
Also, what case is that? It's looking pretty smexy.
My Rig:
CPU: Intel i5 2500k 4 Cores, 4 Threads @ 4.5ghz ( asus uefi regulates BIOS and adjusts it, there is no manual option, so I can't get any higher than 4.5, but I theoretically should be able to get higher once I get a voltage "changeable" mobo
MOBO: Asus P8Z68 LE
RAM: Kingston HyperX Predator 2133mhz ddr3 2x8 16GB
GPU: GTX 980 TI 150+ core, 100-150 ( I forgot )+ mem ( OC )
HDD: 500GB 3D MLC Samsung SSD ( soon ) + 2tb 7200rpm Seagate Constellation ES.2 SAS / LSI MegaRaid MR Raid/SAS Controller
CASE: Phanteks P350X
OS: Windows 10 64-bit / Void Linux
PERIPHERALS: IBM Model M 1984, Logitech G703 Mouse, Logitech G502 Mouse, Philips SHP9500 w/ V-Moda Boom Pro hooked up to my Sony AMP ( forgot model name, to lazy to find out )
Laptop: Gateway P-7805u FX
CPU: 2.26GHz Intel Core 2 Duo P8400 2c/2t
RAM: 8GB DDR2 1066mhz sodimm
GPU: Nvidia GeForce 9800M GTS
HDD: 320GB 7200rpm hard drive 2.5"
SSD: Kingston A400 250GB SSD
SCREEN: Glossy 16:9 1440x900
OS: Windows XP SP3 / Ubuntu 19.04
PERIPHERALSLogitech G Pro
https://linustechtips.com/topic/1067925-ps3-water-cooling/#findComment-12604783
11 minutes ago, Sylvie05 said:
Do they just make waterblocks for PS3s?
koolance made one many years ago, it's extremely hard to find. in the many years I've been wanting to attempt this I've only ever seen one for sale on ebay.
I just had a custom one made based on dimensions for the die of the chips and measurements for the mounting
https://linustechtips.com/topic/1067925-ps3-water-cooling/#findComment-12604856
  • 5 months later...
is there any way I can purchase or have the dimensions of the the chips and the die? I also want to try this. But have had no success.
https://linustechtips.com/topic/1067925-ps3-water-cooling/#findComment-13044313
