Pls help
Go to solution Solved by SupaKomputa,
Reset the bios.
Check the ram with Memtest86.
Pls i just build a budget gaming pc build after i upgraded cpu to Phenom ii x4 925  windows 10 keep crashing even after fresh install with different stop code each time it crash
Spec
Phenom ii x4 925
Asus m2a vm bios 5001 ver
Asus GTX750
Ram 4gb kingston
It worked fine when i using athlon 64 3200+ but after i upgraded it into Phenom II X4 925 it happen
I still dint sleep even thought it 3 a.m just to solve this freaking promblem
https://linustechtips.com/topic/1067800-pls-help/
Reset the bios.
https://linustechtips.com/topic/1067800-pls-help/#findComment-12603577
3 minutes ago, SupaKomputa said:
Reset the bios.
Already reset the bios i dont there any promblem with ram for me to do memtest86 heck i cant even put in my pendrive because my windows 10 can only stay for like 3 minutes before it crash
https://linustechtips.com/topic/1067800-pls-help/#findComment-12603593
Check the temperature, reseat the CPU properly with the heatsink.
https://linustechtips.com/topic/1067800-pls-help/#findComment-12603603
17 hours ago, SupaKomputa said:
Reset the bios.
Promblem fixed there is promblem with ahci i dont why but it happen run on ide mode
When reset the bios i dont not run it in default setting i change ide to raid that why it keep happening thank for the btw
17 hours ago, chen57 said:
Hello,
is the cpu the only thing you changed ?
thank you
https://linustechtips.com/topic/1067800-pls-help/#findComment-12604024
