On 5/26/2019 at 8:29 PM, Joshcanread said:
I'm trying to make a dropdown box but the things are showing up outside the box.
code1.html
The links need to be inside the myDropdown div, whose visibility is controlled by when the user clicks the button, or where you add/remove them based on the button (I suggest visibility as it's simpler).
Also neither of your divs are close
</div>
Suggest looking here
https://www.w3schools.com/jsref/prop_style_display.asp
Set style.display to "none" to make it invisible, and to "block" to make it visible.
