RAM problem
Solved by tedjani,
Go into the BIOS. Look at the dedicated GPU ram. It's probably allocating 1GB or so for the integrated GPU. You can change it from Auto to whatever you feel fine with not having. Like 128MB.
ok i see you should remove one stick start up the pc see how much it registers, shut down remove memory put in next stick try again. if it registers 2gb each time put both memory sticks see what it picks up it could be its not reading one of the sticks as 2gb.
ok i found the problem it from windows i tried to boot up from linux and all 4 GB was working find so thank you guys
