My laptop has a i7 7700hq and a GTX 1050 TI . I am using Cooler Master RG-ICF-CWRP2-GP thermal paste and I am getting 84 C for gpu (It throttles at that and decrease performance) & 93 C for cpu under load.
My question is if i use Artic Silver 5 High Density thermal paste, will it reduce my temperature. I am sorry for this noob question. The Cooler Master thermal paste i am using is around 6 years old. Just wanted to make sure before i placed the order.
Thank you for reading and helping me :)
AS5 is decent, but not near the best anymore. Get something like MX4, NH-T1, GC Extreme, or Kryonaut for the absolute best performance north of Liquid Metal. Laptops are horrible all around for cooling so you may gain a little bit, but likely not much since they really cant effectively move the heat very well.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
So these temprature are normal for laptops. I mean mine is throttling everytime i play a game. I spent 150 PKR usd for a laptop i expect it to give me performance ☹️
1 minute ago, alatron978 said:
Not answering the question but have you tried undervolting? It will decrease the temperatures by a huge amount on the cpu and gpu.
Will it decreases less performance then it would with thermal throttling ?
I repasted my sager NP8372 which has a 7820hk and GTX 1070 with kryonaut and dropped about 11c on the cpu. Undervolting will also help temps A LOT.
I wouldnt reccomend Artic silver 5 in a laptop because it is slightly capacitive. You need a totally non conductive paste in a laptop because youre applying the paste directly to the cpu and gpu dies.
The Beast:
 i9 9900k (5.1Ghz all cores)
2080ti FE
32gb 2x16 trident z royal 3200c14
xi hero mobo
evga 1300 80+ gold
2x 1tb 970 pro
1tb 860 evo
6tb wd red
view 71 case
Custom loop (cpu & gpu)
420 & 360mm rads, ek water blocks.
asus PG279Q 27in 1440p 144hz ips gsync monitor
K70 mk2 k/b, G502 mouse, hyper x cloud revolver s headset.
(FOR SALE)
Sager NP8372
i7 7820hk, GTX 1070, 32gb ram, 17.3 in G sync display at 90hz. 500gb 960 evo. less than 1in thick.
Trident Z rgb 2x16 3200c14
https://linustechtips.com/main/topic/1066259-trident-z-rgb-2x16-3200c14-fs/
45 minutes ago, alatron978 said:
Undervolting doesnt decrease preformance at all. It only decrease the voltage going into the cpu/gpu. You will get the same performance if not better no matter the situation as long as the under volt is stable.
DAMN BOI, You just increased my laptop performance. Thank you so much. I changed the voltage frequency curve and now temps are lower and fps increased. I will post pics when i have the time. :)
1 hour ago, AbdulRahman Nadeem said:
I spent 150k usd for a laptop
That's a LOT of money for a 7700HQ and a 1050Ti.  You could have bought several other laptops for that, and have enough left for a nice car.
I assume you meant 1500 USD, or 1.5K
I'm hoping he meant 150 USD because 1500 and he could've gotten better than a 1050ti..
CPU: Ryzen 5 2600 4ghz @ 1.35v  CPU Cooler: Mugen 5 Rev b  Motherboard: MSI B450 Gaming Pro Carbon  GPU: Zotac RTX 2060 +150/+1000 Memory: 16GB Viper 4 @ 3200 CL14 Samsung B-die  Storage: 1TB Patriot VPN100 NVMe; 500GB 860evo; 128gb 840pro CaseCooler Master Q500L  PSU: CX750M V2 Operating System: Windows 10 Pro Other: 6 Corsair LL Fans; 2 aRGB Strips
On 5/25/2019 at 6:10 AM, Skiiwee29 said:
AS5 is decent...
Not really, it's a capacitive thermal paste that takes entirely too long to cure and under-performs.
The Potato Box:
AMD 5950X
EVGA K|NGP|N 3090
128GB 3600 CL16 RAM
The Scrapyard Warrior:
AMD 3950x
EVGA FTW3 2080Ti
64GB 3200 CL16 RAM
That's not true at all, if you're not dealing with an aluminum cooling system a liquid metal such as Conductonaut is the best thermal compound you can use and that, as the name suggests, is highly conductive. You just need to know how to work with the paste and properly apply it.
The Potato Box:
AMD 5950X
EVGA K|NGP|N 3090
128GB 3600 CL16 RAM
AMD 3950x
EVGA FTW3 2080Ti
64GB 3200 CL16 RAM
way to pick just one specific little segment out of my post and ignore the rest.
Community Standards
"Beast Mode"
The problem is that AS5 isn't a 'decent' paste.
It is, in fact, a bad one since it displays unacceptable problems compared to modern thermal compounds.
The Potato Box:
AMD 5950X
EVGA K|NGP|N 3090
128GB 3600 CL16 RAM
AMD 3950x
EVGA FTW3 2080Ti
64GB 3200 CL16 RAM
sorry 150k PKR ?
