USB c audio compatibility
Go to solution Solved by rice guru,
47 minutes ago, Himommies said:
Can I use a pair of USB c headphones on a phone with a audio jack. Specifically the pixel buds on a OnePlus 5
 As you can see with this video USB c audio are picky. The 6t has proven compatibility with more universal solutions like the HIDIZ's portable DAC amp. So I'm sure would work with the 5
edit:further research leads be to believe what you want to do won't work
