Hey guys, I just bought a 2012 Macbook Pro 13" already max out in upgrades so it runs smoothly. The one problem I really have is that I only have 2 USB ports and that just doesn't works for me I need at least 7 for peripherals such as mouse, keyboard, sound card, EHDD and so on, preferably 10 usb ports for anything extra that i would like to connect. The real question here is, what usb hub is the best in this case? I think speed is not as important for all to work good but im not sure. Hope you can help me.
https://linustechtips.com/topic/1066209-usb-hubs/
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1066209-usb-hubs/#findComment-12588962
6 minutes ago, TempestCatto said:
A USB sound card? Really? I don't know how much better it would be than the onboard your Mac already has. This seems like something you could omit to save space imo.
Yeah probably... For example the speakers I have are from centuries ago they are powered by usb. I'm still new to Mac environment so I have a lot of things to learn.
https://linustechtips.com/topic/1066209-usb-hubs/#findComment-12588977
Just use any decent headset and you should be fine. Or if you really want external speakers, a simple 2.1 kit from your local store should suffice. (of course I'm assuming you're not looking for highend audio)
https://linustechtips.com/topic/1066209-usb-hubs/#findComment-12588980
I was looking forward for some studio monitors cause all the video editing (edm photographer and videographer) so i kinda need the highend audio, but not that kind of money LOL
https://linustechtips.com/topic/1066209-usb-hubs/#findComment-12588984
