i was watching youtube yesterday and then my pc froze so i waited but nothing happened so i held the power switch to shut it off then when i tried to turn it back on it turns on and off then immediately on and off again continuously i have tried unplugging everything and turning it on no change oh and one time while it was tuning on and off it stayed on and got stuck on the msi logo so i turned it off and turned it back on again and it hasn't got to that again screen again
PC Stats:
Motherboard:msi b250m bazooka
hdd:1tb
it came with 8gb RAM 3200 but i put another 2x4 gb so 16 in total (this was months ago i added it )
CPU: intel i5-7400
Gpu: msi rx 580
also it windows 10 idk if that helps
ok new update i took out 2 RAM sticks and now it turns on but nothing goes on my monitors and my keyboard/mouse dont light up either
ALSO i just noticed this now there is 2 white leds lighting up on the side of motherboard they like go up and down
NEW Update the 2 lights are the EZ Debug lights for RAM And CPU
Edited by SageKingTyler
https://linustechtips.com/topic/1065866-pc-boot-loop-help/
12 minutes ago, Radium_Angel said:
Reset CMOS, and what age/quality is your power supply?
how and what happens if i reset cmos and the whole pc was bought on amazon but maade by cyberpower pc it was $720 the whole thing was cheaper then the gpu at the time beacus of mining but i belive psu was thermaltake or something something
https://linustechtips.com/topic/1065866-pc-boot-loop-help/#findComment-12585360
1 minute ago, SageKingTyler said:
i did that
I'm guessing that it can't even get into BIOS? Most likely a hardware issue. I would start by testing individual components if possible. Such as different power supply and RAM to start off with. When you start a computer it does a small check to make sure that everything connected is working, if something isn't working/responding they do what yours is doing.
https://linustechtips.com/topic/1065866-pc-boot-loop-help/#findComment-12585389
but why would it just randomly start doing this
https://linustechtips.com/topic/1065866-pc-boot-loop-help/#findComment-12585407
Hard to say man. Sometimes things just fail or come loose. Most likely it's nothing you've done. Also any way you can connect your hard drive to another machine to make sure it working?
https://linustechtips.com/topic/1065866-pc-boot-loop-help/#findComment-12585420
noot really we have a family pc but i dont relly want ti mess with it
https://linustechtips.com/topic/1065866-pc-boot-loop-help/#findComment-12585462
If the CMOS is corrupt (a possibility) then resetting it will set the BIOS settings back to default (time, date, boot options, etc) but your hard drive and all contents will be fine.
If you don't feel comfortable doing this, take it to a computer shop and have it done.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/1065866-pc-boot-loop-help/#findComment-12585726
but why would it corrupt out of no where
https://linustechtips.com/topic/1065866-pc-boot-loop-help/#findComment-12585736
PC Stats:
hdd:1tb
CPU: intel i5-7400
Gpu: msi rx 580
https://linustechtips.com/topic/1065866-pc-boot-loop-help/#findComment-12585782
If computers were reliable, this forum wouldn't exist.
We start with basic troubleshooting steps, and that includes resetting things back to default.
Are you using the dedicated GFX card or the one built-in to your CPU?
https://linustechtips.com/topic/1065866-pc-boot-loop-help/#findComment-12586617
rx 580
https://linustechtips.com/topic/1065866-pc-boot-loop-help/#findComment-12587411
39 minutes ago, Radium_Angel said:
Try using the built-in one, assuming the mobo has video out capabilities.
Remove RX 580 first
well i looked at the 2 blinking lights and they re the EZ debug lights and the ram and cpu ones are blinking but why would there be  problem with both out of nowhere
https://linustechtips.com/topic/1065866-pc-boot-loop-help/#findComment-12587639
