Hey, I recently picked up a second hand Zotac RTX 2070 Blower Edition however the cooling on the card is far from great. I purchased an Accelero IV however I could not mount it due to this card using a mini PCB. In games like Black Ops 4 the card reaches it's 81 Degrees limit and starts to throttle and is very loud, I am wondering If any air / liquid coolers could be compatible because there is not much info on these mini RTX 2070's online.
https://linustechtips.com/topic/1065781-rtx-2070-cooling/
you could likely still use a G12 kit I suspect. This thread said the G12 worked like a charm on his 1080 mini from Zotac, so would have reason to believe the same here.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1065781-rtx-2070-cooling/#findComment-12584425
I have the blower style equivalent from Asus and so far i have been nothing but impressed. It cools very well even under high workloads and is not even very loud under load. Maybe your card is bad or maybe that model is bad xD. Not saying it has to be that way but i would not rule out the possibility.
https://linustechtips.com/topic/1065781-rtx-2070-cooling/#findComment-12584446
Maybe. Does the asus card have the full size PCB?
https://linustechtips.com/topic/1065781-rtx-2070-cooling/#findComment-12584478
