1 minute ago, YoFavRussian said:
When a graphics card is defecting the best thing is to look for a replacement. You could try baking the graphics card, but honestly it's no guarantee that it will last much longer.
Thank you so much
But truth be told, getting a replacement is quite a bit of work and also very expensive
Am grateful for your support
https://linustechtips.com/topic/1065767-graphics-card-problem/#findComment-12584393
