Need help connecting ODD
By
NiceShice
in Storage Devices
in Storage Devices
Solved by Bishop Crane,
Either of the cables you posted will work.
Its just different options for power, some older PSU's don't have an option for a SATA power connector.
You will definitely need power though, the data connector is for data only.
anothertealtiger ·
Mumintroll ·
Posted in Programs, Apps and Websites3 -
ElDTac ·
HunterSVK ·
Posted in Troubleshooting2 -
Ozzi ·
Posted in Networking5 -
2
MadManMarsBar ·
Posted in Build Logs3 -
IAmAndre ·
Posted in New Builds and Planning8 -
4
play_circle_filled
Latest From ShortCircuit:
