Can you select audio device for that one software? If yes, then you can record just that audio device. If no, but you can select audio devices on everything else (or just those you want to exclude), then you need virtual audio cables and setup them so that recording only records stereo mix and not the virtual audio device which is used by other software.
This is one free solution https://www.vb-audio.com/
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
