1 minute ago, Jam_jam2 said:
I've tried diagnostics but all it says that it has a loose cable but it's all connected ?
so you aren't going to try a different power cable for the optical drive which doesn't have any power then correct?
https://linustechtips.com/topic/1065008-optical-drive-no-power/#findComment-12577442
