Video + Sound Alignment Failure
Go to solution Solved by Hans Christian | Teri,
I know it's not the answer you want, but using better software like Premiere Pro or Vegas would probably fix your problem.
So i'm editing with Cyberlink PowerDirector 11 (Trial) and the audio and video keeps getting apart. When editing it appears to be aligned, and sometimes gets off, but when I produce it the the audio is about .5 seconds ahead (or video .5 seconds behind).
Does anyone know any solutions or what this problem is? Thanks.
"When in doubt, don't take your wallet out." - Dad
† TTCF Member †
https://linustechtips.com/topic/106481-video-sound-alignment-failure/
