Could someone tell which air cooling (i would prefer not to go with liqued) up to 50 euros? Its ok if i need to go up with money (maximum 85euro), if its worth it. I have ryzen 2600. Main task for for cpu fan is to be silent while on heavy load, and of course to provide me some overclocking possibilities while still being silent.
I found noctua nh-d15 for 85 euro, are there better deals?
https://linustechtips.com/topic/1064368-air-cooler-for-cpu/
Dark Rock 4
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1064368-air-cooler-for-cpu/#findComment-12572122
A Cryorig H7 is a really good cooler if you don't have much money. I use an H7 on my Ryzen 5 1600 and the temps rarely go above 65C in games, it's super quiet as well.
Computer engineering PhD student and RFML researcher
Daily Driver:
CPU: Ryzen 7 4800H | GPU: RTX 2060 | RAM: 32GB DDR4 3200MHz C16 | OS: Debian 13
Gaming PC:
CPU: Ryzen 5 5600X | GPU: EVGA RTX 2080Ti | RAM: 32GB DDR4 3200MHz C16 | OS: Windows 11
https://linustechtips.com/topic/1064368-air-cooler-for-cpu/#findComment-12572130
Unfortunately those are hard to find these days, otherwise a solid cooler if it can be bought.
3 minutes ago, Princess Luna said:
Dark Rock 4
Or the new dark rock slim when it's available
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1064368-air-cooler-for-cpu/#findComment-12572138
1 minute ago, trevb0t said:
I know the Pro 4 is a blowout, but do the 4 or slim outperform a 212 Black?
Yes, the slim is a 180 watt and the DR4 is 200w. Still quite a lead in cooling performance
Primary PC:
PSU tier list
https://linustechtips.com/topic/1064368-air-cooler-for-cpu/#findComment-12572148
Regarding Cryorig H7, there is no classic version of it, only those variants of it...
Cryorig H7 ultra 50 euro
Cryorig H7 plus 50 euro
Cryorig H7 quad lumi 55 euro
Cryorig H7 quad snow 65 euro
And,  dark rock 4 is 62 euro.
So, with which one should i go? ( Prefering more silent one).
https://linustechtips.com/topic/1064368-air-cooler-for-cpu/#findComment-12572177
1 minute ago, LukeSavenije said:
you might want to quote people...
I'd take either of them
quad lumi is with rgb, snow is white, the other two I'm not sure
the drp4 is more silent tho, and technically enough for even a 9900k
Good suggestion regarding quotes.
I guess they wont even see question this way.
Hmm, is there actualy noticable difference between dark rock 4 and dark rock pro 4 regarding noise while full load?
https://linustechtips.com/topic/1064368-air-cooler-for-cpu/#findComment-12572194
The Cryorig H7, even though it is very good, is only a 3 heatpipe cooler. I would step it up to the Scythe Mugen 5 Rev. B which is 6 heatpipes and known for it's silence and is the same price.
https://de.pcpartpicker.com/product/8GBrxr/scythe-mugen-5-rev-b-512-cfm-cpu-cooler-scmg-5100
https://linustechtips.com/topic/1064368-air-cooler-for-cpu/#findComment-12572196
H7 Plus is the H7 w/ an extra Fan.
H7 Ultra is the H7 w/ RGB and a extra heatpipe.
H7 Quad Lumi is the H7 w/ extra heatpipe, white LED fan, RGB top & underglow
Snow is H7 quad Lumi thats white.
Get the Ultra.
https://linustechtips.com/topic/1064368-air-cooler-for-cpu/#findComment-12572199
5 minutes ago, Bearmann said:
When overclocked at load, the Mugen 5 pulls ahead of the Dark Rock 4.
https://www.overclockersclub.com/reviews/scythe_mugen5/3.htm
Whatever you get, make sure that it fits your case.
But if i overclock it, wouldnt it then be very loud? I have ear problem, so noise is most important for me. I have to adming this mugen 5 realy caught my eye, just noise worries me
https://linustechtips.com/topic/1064368-air-cooler-for-cpu/#findComment-12572285
Scythe is known for making quiet coolers. It would be perfect if it fits your case. If it did get too loud, you could decrease your overclock a bit.
You can see the noise levels on these last two charts:
https://www.tweaktown.com/reviews/8320/scythe-mugen-5-rev-cpu-cooler-review/index6.html
https://linustechtips.com/topic/1064368-air-cooler-for-cpu/#findComment-12572359
The Mugen 5 is pretty quiet.
What case and ram are you using? Where are you shopping / located?
https://linustechtips.com/topic/1064368-air-cooler-for-cpu/#findComment-12572435
13 hours ago, thinwalrus said:
Scythe Mugen5 orFuma and Thermalright Macho rev B are all quite nice for about 40-50€:s. Silentiumpc Fortis 3 is a bit cheaper at 35€. Prices from amazon.de, could be cheaper on other countries.
Im shoping in serbia and bosnia. Murgen is 50 euro. My case is ms falcon, b450 tomahawk motherboard and ripjaws 3200mhz ram 8gbx2
would it fit?
https://linustechtips.com/topic/1064368-air-cooler-for-cpu/#findComment-12573871
This lists the MS Falcon as 161mm maximum cooler height.
http://www.pc-specs.com/case/MS/MS_Falcon/2727
The Scythe Mugen 5 Rev. B (5100) is 154mm. The M5RB is offset from the RAM, so it can work with any RAM height as you can see in these photos:
https://www.tweaktown.com/reviews/8320/scythe-mugen-5-rev-cpu-cooler-review/index5.html
So in summary, yes it fits! ?
https://linustechtips.com/topic/1064368-air-cooler-for-cpu/#findComment-12574072
