Hi so idk if this goes here but it's sort of case related:
Is it possible to get a corsair Lighting Node Pro to remember a default RGB setting so it looks a certain way even if iCUE isn't open on the PC?
If not can the Commander Pro do that?
thanks
-Parts-
Core i7 8086k 4.0GHz (4.6GHz OC) - ASUS z390 ROG Maximus XI code - Corsair H115i - 16GB (2 x 8GB) G.SKILL Trident Z RGB 3600MHz - Windforce GTX 1050Ti - Corsair HX750i - Corsair Obsidian 500D RGB SE
-Upgrades when I get the money-
Undecided on the GPU - ASUS ROG PG278QR 1440p 144Hz (165Hz OC)
https://linustechtips.com/topic/1064178-lighting-node-pro-memory/
1 minute ago, Den-Fi.com said:
I have a commander pro and it doesn't retain settings anymore after the last firmware upgrade. Annoying because I used to set it in Windows, then go back to Linux. Now I just get rainbow vomit when I switch. Corsair seems to have no plans to address this.
that's a shame :(
I have the lighting node pro and it doesn't retain colours and stuff but I just thought that it was because it's the worse version
-Parts-
thanks
Both Lighting Node Pro and Commander Pro have HW Lighting available in the iCUE software.  Double check and make sure you're on the latest version which should be 3.15.101.  You will need to set the lighting per channel.
Looking for more details about a product, or experiencing technical issues?  Visit our support page below, and one of our Technical Support staff can help you out:
https://support.corsair.com/
Thank you so much! I never noticed that little button. Maybe make it more obvious in newer versions?
-Parts-
You'll wanna hear this
-Parts-
Oh nice! I haven't updated in a while since I don't use Windows on that machine often.
Thanks!
