Hey guys, I just started having this issue on my pc, anytime I open game, for example fortnite my audio keeps cutting out entirely and you hear like 2 weird speaker "pop" noise and the only way to to restore audio is to restart the entire pc. The speaks sounds so weird and distorted like they been damaged but when plugging the jack into something else like a phone or laptop it sounds good. I kinda solved the cut out issue by removing realtek drivers but the audio still sounds horrible, idk whats going on. Using on Board audio jack.
https://linustechtips.com/topic/1063376-audio-cutting-out/
Does it sound like static?
Crimson Panda
http://pcpartpicker.com/list/g6T8QV
AKG K712 PRO
OL DAC
Magni 3
https://linustechtips.com/topic/1063376-audio-cutting-out/#findComment-12561859
26 minutes ago, KyiloRen said:
Yes it does o_O
its possible your onboard audio is just picking up electrical noise due to the fact that it's inside your pc and is possibly poorly shielded. you typycally fix this issue byu getting an external solution possible a DAC.
https://linustechtips.com/topic/1063376-audio-cutting-out/#findComment-12561977
On 5/12/2019 at 7:32 PM, KyiloRen said:
Yes it does o_O
This is my thought, although it's weird. Considering your device likely isn't from a very long time ago, noise shielding shouldn't be an issue. Nonetheless, try plugging in your headphones to the back of the case, directly to the motherboard instead of the onboard header.
Crimson Panda
AKG K712 PRO
OL DAC
Magni 3
https://linustechtips.com/topic/1063376-audio-cutting-out/#findComment-12567236
Still nothing, the audio only cuts out when Install the correct realtek drivers and only rarely when uninstall.
https://linustechtips.com/topic/1063376-audio-cutting-out/#findComment-12573137
ye then a dac would be my guess.
Crimson Panda
AKG K712 PRO
OL DAC
Magni 3
https://linustechtips.com/topic/1063376-audio-cutting-out/#findComment-12577466
