I added a Dark Rock Pro 4 to my system today. Following installation both CPU fans (plugged into CPU Fan header with Y splinter) and one of the front case fans (plugged to Sys Fan 3 Header) were not working. I rechecked the cables were plugged all the way in. I eventually got the Dark Rock fans spinning by plugging to the CPU OPT header. The case fan is still not working. I'm thinking some of the fan connectors are damaged. I have no more free fan connectors. My current plan to fix is to get a Y connector and plug the non functioning fan into one of the other headers that are working. Any other suggestions?
https://linustechtips.com/topic/1063256-fans/
Have you checked what speed the fan header is set to? Try setting it to 100% rpm and seeing if the fan still doesn't start up.
Moved to Air Cooling.
https://linustechtips.com/topic/1063256-fans/#findComment-12560589
I tried maxing out the fans when i saw the CPU cooler fans weren't running.  The fan which is currently not working also have a solid white LED on it which is also not lit, so I think the problem is more that it is not receiving power.
https://linustechtips.com/topic/1063256-fans/#findComment-12560594
Have you tried swapping the fans that are spinning and the ones that aren't and seeing if the problem persists with the fans or the motherboard header?
https://linustechtips.com/topic/1063256-fans/#findComment-12560596
