I'm going to do a PC build as a gift for a family member that does not need a dGPU and likes very small PCs. Does anyone have some recommendations other than the InWin Chopin for a SFF mITX case that doesn't have a GPU bay?
I spend too much on my PC. Then I spend even more on my Sim Rig. Damn, this stuff's expensive.
https://linustechtips.com/topic/1063188-case-for-apu-based-sff-mitx-pc/
Community Standards
"Beast Mode"
Dedicated Streaming Rig
Why not go with the ASROCK A300 then??
Its small, made for AMD and build for that so no hassle with putting hte Board inside a case and other shit. Only putting a Drive or two inside (Case supports 2x2,5" and 2x M.2 SSDs), CPU and Memory (SO-DIMM) and be done with it.
Other Options are for example Antec ISK110 but that's really really close and only if you know you don't use it at 100% load often.
"Hell is full of good meanings, but Heaven is full of good works"
Intel NUC is what you need.
Get the Devil Canyon variant if you need it to be able to gaming also.
My system specs:
CPU: Intel Core i7-8700K, 5GHz Delidded LM || CPU Cooler: Noctua NH-C14S w/ NF-A15 & NF-A14 Chromax fans in push-pull cofiguration || Motherboard: MSI Z370i Gaming Pro Carbon AC || RAM: Corsair Vengeance LPX DDR4 2x8Gb 2666 || GPU: EVGA GTX 1060 6Gb FTW2+ DT || Storage: Samsung 860 Evo M.2 SATA SSD 250Gb, 2x 2.5" HDDs 1Tb & 500Gb || ODD: 9mm Slim DVD RW || PSU: Corsair SF600 80+ Platinum || Case: Cougar QBX + 1x Noctua NF-R8 front intake + 2x Noctua NF-F12 iPPC top exhaust + Cougar stock 92mm DC fan rear exhaust || Monitor: ASUS VG248QE || Keyboard: Ducky One 2 Mini Cherry MX Red || Mouse: Logitech G703 || Audio: Corsair HS70 Wireless || Other: XBox One S Controler
My build logs:
