Hey there,
I recently finished building my new rig, however it does not want to turn on.
It has the 9900K and Z390-A motherboard with a deepcool240L watercooler.
When plugging it in the RGB starts up, then once i hit the power button, the CPU cooler, power supply and graphics card all start lighting up.
However, none of the fan spins and there is no post or beeping noise coming from the motherboard.
I checked for bent pins and could not find anything unusual, as well as re-slotted the memory slots, power cables, and fan cables.
Not sure if anyone has any opinions to fix it. Was going to take it back to the store and see if they could do anything.
https://linustechtips.com/topic/1063153-no-fan-spin-no-post/
Try taking the ram out and getting to bios
Main PC
i5-9400f @2.9GHz | Corsair H100i Elite Capellix |Gigabyte RGB GTX1060 6GB | Corsair CX650M | Island Professional 120GB SSD | Toshiba 2TB HDD | Corsair Vengeance RGB Pro 2x16 DDR4 3200MHz  | Corsair iCUE 220T | Windows 10 Pro | CPU R20 Cinebench Score -  pts | OpenGL FPS -  FPS | Novabench Score (OC) -  Base -
Keyboard and Mouse
Corsair K70 RGB MK.2 Cherry Mx Red | Corsair Glaive RGB
Streaming PC (HP Compaq 8100 SFF)
Xeon X3440 @2.53GHz | Radeon HD 6450 | HP Compaq 240watt PSU | Toshiba 1TB HDD | Samsung 2x4 DDR3 1333MHz | HP Compaq 8100 SFF | Windows 10 Pro | CPU Cinebench Score - 409 cb | OpenGL FPS - 16.77 FPS | Novabench Score (OC) - 991 Base - 938
Keyboard and Mouse
Logitech G413 Silver White LED Romer-G Switch | Old Gateway Mouse
Monitors
AOC - 21.5" IPS LED FHD Model - l2279VWHE | AOC - 24" TN Panel FHD 144hz 1ms Response - Model G2460PF
https://linustechtips.com/topic/1063153-no-fan-spin-no-post/#findComment-12559790
