best current gpu to match with a i5 3570k.
Solved by MS-DOS Guy,
Get a used GTX 980 TI. There around the budget you mentioned and are basically GTX 1070s with slightly lower vram. If you think it will bottleneck your processor, just overclock it assuming you have a Z-Series motherboard. A while back, I had a i5 2500k rig that did bottleneck my 980 ti ( this rig was a while back, I had to sell it so I could afford a server I wanted to build ) but overclocking fixed the problem drastically. Another good option would be a GTX 1070 but there usually a tad more expensive. But since the RTX line-up came in recently, all the previously expensive cards have dropped in value.
