i just realised after looking into my gpu and my base clock should be 1276 MHz and gpu boost clock speed should be around 1560 MHz yet during anygame im only getting around 1100mhz and wont go anyhigher and my temps will not go above 70c-75c. GIGABYTE RX Vega 64 GAMING OC this is the gpu is have
https://linustechtips.com/topic/1062857-need-help/
5 minutes ago, Craziii said:
how do i know what my limits are ?
use MSI afterburner's on-screen display, check if CPU/GPU temps are hitting thermal limits or if the CPU is stuck at or close to 100% while gaming.
https://linustechtips.com/topic/1062857-need-help/#findComment-12557266
I have a stupid question. what settings are you playing at? if you're only playing @ 1080p on medium ish settings youre vega 56 has no need to boost up to its max.
Case Fractal Design Define R6 MOBO: Gigabyte z390 Aorus Elite CPU: i9 9900k Cooler: Fractal Design Celcius S24 GPU: Gigabyte Aorus Waterforce Extreme 1080tiMemory Tforce ddr4 3200 c14 32GB 4x8 Storage SSD Kingston 240GB SSD, intel660p 1TB m.2 Samsung 860 EVO 1TB m.2 PSU Corsair HX1200
https://linustechtips.com/topic/1062857-need-help/#findComment-12557269
thats what im using and my cpu doesnt go above 70c (9600k) it only goes to 75c when ive played for long same with the gpu stays around 70c to 75c doesnt go above and im on rust now and my cpu usage is 70% and gpu is 75%
https://linustechtips.com/topic/1062857-need-help/#findComment-12557270
and its vega 64 and im stuck at 1095 mhz on clokc when the base is 1276 and im not trying to boost is it just my main game rust i play is very unoptimized and me seeing that im getting lower clock speed than my base speed is worrying to know that im missing on soo much fps and my bost should be around 1300-1500
https://linustechtips.com/topic/1062857-need-help/#findComment-12557274
Just now, Craziii said:
i play every game no matter what 1080p lowest settings possible
did you run v-sync with your games?
https://linustechtips.com/topic/1062857-need-help/#findComment-12557280
same difference. 56 or 64. what in game settings are you playing at in your 2 games? if you're not trying to push past 1080 ultra at high frames your card is not going to boost up.
https://linustechtips.com/topic/1062857-need-help/#findComment-12557286
turn your settings up and your memory and boost clocks will get closer to their max l. 1080p at the lowest settings is child's play for that gpu.
https://linustechtips.com/topic/1062857-need-help/#findComment-12557292
ooh yh i just done that on rust turned everything up and now im hovering around 1350-1460. ty man i didnt know it worked like that dont know if it only with amd card but this is the first time with one.  and question if i undervolt the card if you were to compare the card to a nvidia card what would it be ? i was told to do it by loads of ppl to reduce the temps and power draw and that give me more performance i dont know how much tho
https://linustechtips.com/topic/1062857-need-help/#findComment-12557304
ooh yay i just done that on rust turned everything up and now im hovering around 1350-1460. ty man i didnt know it worked like that dont know if it only with amd card but this is the first time with one.  and question if i undervolt the card if you were to compare the card to a nvidia card what would it be ?
1070ti 1080
somewhere in between. depends on the game
https://linustechtips.com/topic/1062857-need-help/#findComment-12557308
