Will I need another cooler?
Go to solution Solved by nsyedhasan,
Hey I just bought manh pieces for my pc and unfortunatly I may have bought the worng cooler. I bought the Zalman LQ310 and my hardwares are:
Cpu:I7 4771
Motherboard: Asus Z87 plus
Gpu: Gtx 780ti
Ssd: 840 EVO
Psu: RM850
Hd: 2T bur I forgot the brand
Ram:16gb
Will my cooler be enought? Thanks guys :)
Nope, it will work.
Cpu:I7 4771
Gpu: Gtx 780ti
Ssd: 840 EVO
Psu: RM850
Ram:16gb
https://linustechtips.com/topic/106260-will-i-need-another-cooler/
Cpu:I7 4771
Gpu: Gtx 780ti
Ssd: 840 EVO
Psu: RM850
Ram:16gb
Nope, it will work.
Quote me to get a reply!
Nope, it will work.
Unless it doesn't fit his case....
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
I didnt buy the case yet, so i'll buy one that fits everything hahahhaha. Thanks for the help guys!
It would be best to go to the manufactures site for the CPU cooler and check the dimensions and double check the size against the dimensions of any potential case to avoid not being able to put your side panel on.
Make sure you get a properly sized case for it. :D
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
