So I finally got my 2080ti but it's been having a lot of issues.  I've noticed in most games it isn't hitting the max FPS I set in game.  I checked the usage which sits from 30-60% depending on the game but unless it's a very low resource game it doesn't hit 144hz.  When I play league it's around 120hz with 40% usage, in BO4 it's still 120hz but 60% usage.
I do not think this is a bottleneck because my cpu usage is around 50% in most games and most of my ram isn't being used.
I've tried changing the power in 3d graphics settings in the nvidia control panel to best performance, installing afterburner and increasing the power limit, and using the task manager to set the games priority to high and nothing changed at all.
https://linustechtips.com/topic/1062552-low-gpu-usage-low-fps/
What CPU, and what resolution?
Primary PC: - https://pcpartpicker.com/list/8G3tXv (Windows 10 Home)
HTPC: - https://pcpartpicker.com/list/KdBb4n (Windows 10 Home)
Server: Dell Precision T7500 - Dual Xeon X5660's, 44GB ECC DDR3, Dell Nvidia GTX 645 (Windows Server 2019 Standard)
*SLI Rig* - i7-920, MSI-X58 Platinum SLI, 12GB DDR3, Dual EVGA GTX 260 Core 216 in SLI - https://pcpartpicker.com/list/GHw6vW (Windows 7 Pro)
HP DC7900 - Core 2 Duo E8400, 4GB DDR2, Nvidia GeForce 8600 GT (Windows Vista)
Compaq Presario 5000 - Pentium 4 1.7Ghz, 1.7GB SDR, PowerColor Radeon 9600 Pro (Windows XP x86 Pro)
Compaq Presario 8772 - Pentium MMX 200Mhz, 48MB PC66, 6GB Quantum HDD, "8GB" HP SATA SSD adapted to IDE (Windows 98 SE)
Asus M32AD - Intel i3-4170, 8GB DDR3, 250GB Seagate 2.5" HDD (converting to SSD soon), EVGA GeForce GTS 250, OEM 350W PSU (Windows 10 Core)
*Haswell Tower* https://pcpartpicker.com/list/3vw6vW (Windows 10 Home)
*ITX Box* - https://pcpartpicker.com/list/r36s6R (Windows 10 Education)
Dell Dimension XPS B800 - Pentium 3 800Mhz, RDRAM
In progress projects:
*Skylake Tower* - Pentium G4400, Asus H110
*Trash Can* - AMD A4-6300
*GPU Test Bench*
*Pfsense router* - Pentium G3220, Asrock H97m Pro A4, 4GB DDR3
https://linustechtips.com/topic/1062552-low-gpu-usage-low-fps/#findComment-12554354
3 minutes ago, Leux said:
i7 8700k with 32gb of ram (in case that matters) and its 2560x1440 resolution.  Also I don't think this is the issue but is an 850 watt power supply enough for these components?
850W is overkill.
hmmmm
The only thing I could think of is resolution, but with that CPU and GPU, max settings should be easy to reach 144fps with.....
Have you tried DDU-ing the drivers and clean installing them yet?
*GPU Test Bench*
https://linustechtips.com/topic/1062552-low-gpu-usage-low-fps/#findComment-12554371
51 minutes ago, Eastman51 said:
850W is overkill.
hmmmm
Ok so I DDUd and reinstalled all the drivers and launched up a custom game on league.  The second I loaded in it was 300 fps (uncapped just for testing) so I thought my problem was solved but when I started casting spells and just generally having stuff happen on the screen it dropped to around 120 again still the same usage.  I tested out BO4 too and it's now around 130-140 fps with rare drops to around 90 that didn't last very long so maybe it's only an issue with league?
https://linustechtips.com/topic/1062552-low-gpu-usage-low-fps/#findComment-12554458
