Seems like a really odd place to post this for help but the LTT community is always super helpful and the garage thread it quite big here so here goes.
My car comes with 195x15R or 195x16R alloys from factory but I've been eyeing up some 205x16R alloys online recently and I was wondering if they would fit properly. Car is a 2015 Ford KA Mk2
Cheers in advance, James.
CPU: R5 3600 @ 4.4 GHz
RAM: 16GB DDR4 @ 3200 MHz
GPU: RTX 2080 Super
https://linustechtips.com/topic/1062458-car-question/
Possibly. Size wise they're not much wider than factory, but you need to check the stud pattern is correct, and check the offset is within a suitable range. A quick google reveals this site https://www.wheel-size.com/size/ford/ka/2015/ which should let you play around with what will and won't fit. Do you have a link to the wheels you want?
https://linustechtips.com/topic/1062458-car-question/#findComment-12553733
