Hello everyone! I have created a program that is supposed to read files. All the codes are correct, but I'm just getting an error that it can't find a file. I create a simple txt file using notepad and saving it. I am still getting errors it cant find it but I know its there. Can someone help me? Thanks!
fname = input("Enter the name of the file:")
infile = open(fname, "r")
lines = 0
words = 0
characters = 0
for line in infile:
    wordslist = line.split()
    lines = lines + 1
    words = words + len(wordslist)
    characters = characters + len(line)
print(lines)
print(words)
print(characters)
THIS IS THE ERROR IM GETTING WHEN RUNNING IT BELOW:
Enter the name of the file:lamb
Traceback (most recent call last):
  File "C:\Users\Bryan\AppData\Local\Programs\Python\Python38\HW extra credit #1.py", line 2, in <module>
FileNotFoundError: [Errno 2] No such file or directory: 'lamb'
 RESTART: C:\Users\Bryan\AppData\Local\Programs\Python\Python38\HW extra credit #1.py
Enter the name of the file:lamb.txt
FileNotFoundError: [Errno 2] No such file or directory: 'lamb.txt'
https://linustechtips.com/topic/1062290-python-help3/
If the file in the same place as your python script?
In python it will take context from where you run it.
So if you have your script in a folder called fileReader when you run python in the folder it will look for
Path/to/fileReader/lamb.txt
If the file was in a folder called files you would need to load files/lamb.txt
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/1062290-python-help3/#findComment-12552111
11 hours ago, fpo said:
When you type in it’s best to use a complete directory. IE
C:/users/JohnDoe/documents/file and.txt
you need quotes if you have ANY spaces.
This isn't required for things like custom modules so why would it be needed here?
https://linustechtips.com/topic/1062290-python-help3/#findComment-12554737
15 minutes ago, fpo said:
It’s required for c# so I thought it would be required for python too.
Even c# should be able to take a relative path else how would programs work across machines?
So we both pull the same code I won't have the same file path as you.
https://linustechtips.com/topic/1062290-python-help3/#findComment-12555954
C# can do relative file paths.
I prefer absolute paths.
I just phrased things poorly.
https://linustechtips.com/topic/1062290-python-help3/#findComment-12556180
There can be only 2 mistakes.
One was pointed out, file isnt in same folder as script.
but....
probably its this problem:
You didnt typed extension in the input. That means you cant input just filename you need to input filename.txt (or whatever extension it has)
instead of lamb, try with lamb.txt
or
change code to infile = open(fname = '.txt', "r")
https://linustechtips.com/topic/1062290-python-help3/#findComment-12564845
