I want to install cyanogen mod 11 on my htc one tonight and I can't use the installer because my phone is with bell and it wasn't recognized.
Can anyone link me all the files I need to install and a guide preferably with photos on how to install it. I don't need to keep anything on my phone but you're still suppose to backup the os right?
Thanks, I'm new to phones, this is my first one ;) (<-- pun)
https://linustechtips.com/topic/106194-cyanogenmod-help/
dafuq is bell
https://linustechtips.com/topic/106194-cyanogenmod-help/#findComment-1419738
http://www.thesmokingandroid.com/htc-one-unlock-bootloader-root-easiest-method-noob-proof-u-s-canadian-international/
You have to unlock your bootloader, flash a custom recovery, then flash the cyanogen mod zip.
“The value of a college education is not the learning of many facts but the training of the mind to think”
https://linustechtips.com/topic/106194-cyanogenmod-help/#findComment-1419770
If you want some specific info and help. I think you should post on the xda developer forums. maybe?
Wanna hang out with me and people like @Theslsamg, @ Ssoele, @BENTHEREN, @Lanoi, @Whiskers, @_ASSASSIN_, @Looney, @WunderWuffle, and @nsyedhasan. Well.... Check out: http://linustechtips.com/main/topic/48484-unofficial-linustechtips-teamschnitzel-server-teamspeak/
https://linustechtips.com/topic/106194-cyanogenmod-help/#findComment-1419821
If you cant install CM using installer then you will need to download the latest CM from there site for your phone and flash it through a custom recovery like TWRP or CWM.
THE PIT VIPER SPECS
4790k @ 4.7ghz  (EVGA CLC 360MM) | 32GB Patriot Viper Extreme @2133 mhz | Asus Z97-DELUXE Cooler Master H500M.| EVGA RTX 2080 Ti FTW3
https://linustechtips.com/topic/106194-cyanogenmod-help/#findComment-1423941
bell and other carriers have a tendency to not allow their costumers to unlock the boot loaders on their phone ( had this problem with my Xperia T from rogers) and to install CM you HAVE to unlock the bootloader of your phone.
but this might only be a problem for Sony devises or it might not be.
here is a link to the KK CM10 on XDA
http://forum.xda-developers.com/showthread.php?t=2579229
browse around the site and you will find a how to guide on unlocking and installing Recovery and Rooting the phone
https://linustechtips.com/topic/106194-cyanogenmod-help/#findComment-1423977
