Well in order for Rasdial to be in question, someone had to manually establish a connection to a RAS Server. I assume you have installed a virus in some way. This appears to be a common malware virus. Thus, secretly establishing a connection to the RAS Server @Zachary Wyatt
https://linustechtips.com/topic/1061517-help-tech-issue/#findComment-12543998
do you know how i could stop it
https://linustechtips.com/topic/1061517-help-tech-issue/#findComment-12544003
First, I want to confirm that these are true:
  • rasdial.exe occupies an unusually large CPU memory
  • Erratic internet connection
  • Your browser is bombarded with annoying ad popups
  • Computer screen freezes
  • PC's processing speed suffers
  • You are redirected to unknown websites
https://linustechtips.com/topic/1061517-help-tech-issue/#findComment-12544005
No not really just CMD poping making the pc almost unusable
https://linustechtips.com/topic/1061517-help-tech-issue/#findComment-12544013
