So I'm thinking of buying either the Oculus quest or the rift s, but I am still just a bit confused about a couple of things:
What is the difference between their two stores?
What games are not available on the quest, buy are on the rift s?
I know they aren't released yet, but if you can answer these questions, that's great.
Thanks!
Specs:
Motherboard: Gigabyte Z97X Gaming 3
CPU: Intel Core I7 4790K
GPU: Gigabyte G1 Gaming GTX 970
RAM: HyperX Fury 16GB
HDD: Seagate ST3000DM001 3TB
SSD: KINGSTON SV300S37A480G 450GB
Cooler: Corsair H100i GTX
Case: NZXT H440 Red
Monitor: DELL U2412M
Keyboard: Gigabyte Force K7
Mouse: Corsair Sabre RGB
https://linustechtips.com/topic/1060973-oculus-quest-help/
The Rift S can be used for any pc game w/ vr support (Steam vr, Oculus store, etc.) whereas the quest is limited to the Oculus store.
Resident Mozilla Shill.   Typed on my Ortholinear JJ40 custom keyboard
               __     I am the ASCIIDino.
              / _)
     _.----._/ /      If you can see me you
    /         /       must put me in your
 __/ (  | (  |        signature for 24 hours.
/__.-'|_|--|_|
https://linustechtips.com/topic/1060973-oculus-quest-help/#findComment-12539181
So do you know what games the rift s can play that the quest can't, like storewide or individual games?
Specs:
Case: NZXT H440 Red
https://linustechtips.com/topic/1060973-oculus-quest-help/#findComment-12539228
